I could use some sage wisdom from you guys on which type of heater to get.
I'm getting tired of using a kerosene heater,( the odour plus the moisture build up after the shop gets cold, not to mention my fear of blowing myself up every time I light it).
First of all I want to heat by natural gas as there is an old BBQ hook-up right outside the door plus it is still fairly cheap compared to hydro so I could leave it set at about 40 degrees F all the time.
My main concern is that a heater with a fan to circulate the warm air will also keep the fine grinding particulate circulating in the air long after grinding is finished requiring me to wear a respirator just about all the time.
An exhaust system would just blow the warm air out with the dust.
How do you guys in the COLD areas heat your shops?
Anybody have any experience with a self contined tube type heater that draws and vents to the outside. It is a radiant heat model.
Thanks for your input
Jim Ziegler
Jim Ziegler
