- Aug 1, 2000
I was making some acrylic (plexiglass) retail display fixtures for the Bladeshow and was terribly frustrated with the finish on the cut edges. I used my horizontal grinder to clean up the edges after bandsawing them....but the sanded finished looked like smeared melted plastic...which is was. I tried different grits and slower speeds but just couldn't get the finish that I wanted without scrapping the edges with a tool. Out of desperation, I grabbed a wax stick of tapping compound and shoved it into the spinning belt to charge it with lubricant. Then ground the plastic with amazing results!!!! The plastic no longer melted on the belt. The edges came out beautiful right off the machine!!!
So if you are having troubles with the finish on a unique material due to heat, gummy-ness or burning. Try lube on your belts. The stuff that I used is from MSC I believe. It is sold as a tapping/sawing lubricant in a waxy like bar. Just shove the bar into the belt or saw blade to charge it. I use it mostly on the band saw for sawing aluminum...and for tapping. But now I will use it more on the belt grinders. I also tried it on a buffer with plastic .... with improved results also!!
I'm so pleased I had to share this with someone!
Hope it helps.
Sincerely,
Rob
Hope it helps.
Sincerely,
Rob
