The Short Revolution appears to be meant to hold in the open position by the opposition of the button lock against a stop pin mechanism inside. A pin goes through the blade and there is a u-shaped cutout in the inside of both handle slabs to let the pin rotate through the open/close arc.
When closed, it's all just the button lock holding it in place, and you can tell there is no opposing pin because the blade wiggles up and down a little. When opened, mine appears to have very good alignment between the tang/clip and the handle.
I assumed the internal stop pin was set up to make the tang stop rotating at that point, but it is not. I removed the flipper part of the clip when considering modifying the knife (removal of clip portion and grinding in a bottle opener), and I notice the blade rotates open just a little further, messing up the handle/tang alignment. It seems useless to have the internal pin if the clip flipper is going to be the stopping mechanism, and of course it seems cheap to use a bent and twisted piece of spring wire for that purpose.
Is the internal pin supposed to make contact AFTER the clip spring does? Does anyone have one that remains perfectly aligned when the clip spring is removed? It's easy, you just pull it outwards with your fingers, one side at a time.
