- Jun 17, 2001
Here's one I've been working on for at least the last couple weeks. Originally when I forged this blade I was thinking the steel was W-2. I thought that because that's what I had written on it. The steel for this blade started out as a good sized barrel shaped bearing. A couple years ago I took more of those bearings and some Hansen W-2 and had them forged out into more user friendly sizes. I should have marked the steel right after forging but didn't. I figured I could identify which was which by the spark. Was I ever wrong. Finally after the second try at a failed heat treat I was positive the steel wasn't W-2. The 3rd and final try I treated it as 52100 and it finally worked. I also used clay on the blade and did get a nice hamon although its not all that easy to spot in the pictures. The blade is 15 3/4" with an overall length of around 22". The blade is just under 2" at the widest. Its got wagon wheel fittings and a western elk crown handle. I'm going to hold off on epoxying it for a few more weeks. My son is getting married in July and I'm going to ask him if he wants to use it to cut the cake at the wedding.
