Short writeup on the new Spyderco SPOT
Cross-posted to GlockTalk,BladeForums, and SDF
First let me get the negative stuff out of the way:
I must say that I'm pretty disappointed with the fit and the finish on this knife. The entire inside of the skeletonized handle is completely unfinished. On this inner portion of the handle, the micarta scales do not sit flush with the steel handle at all. Furthermore, they are rough and grainy, like sandpaper, and adhesive residue is visible at a couple points.
The various machining points on the blade also look rough. The edge grind itself looks choppy, as if someone took it to the grinder with a shaky hand. Still, the edge is extremely sharp. Also, the chamfering looks wavy, or rough at points.
The sheath is loose and allows a slight rattle of the knife. I tested retention by bouncing the knife up and down on its chain and other such tests and the sheath held fine. Still, it's a bit loose on the draw. I would prefer something that clicked in with more confidence. Out of the various neck knives I have owned, this one takes the least amount of force to unsheath. Not so loose that it will fall out from daily activity, it seems, but it still makes me nervous.
I don't know if this is how all of the SPOTs are leaving the factory or if I just got a lemon. I hope the latter as this certainly isn't the kind of work that Spyderco should be known for. But I am a bit worried as the last two Spydercos that I purchased new before this one also had problems. Namely, I received a Meerkat with a rounded tip, and a Chinook with a crappy factory edge. These just struck me as luck of the draw at the time but now I'm wondering if I'm seeing a dip in Spyderco's QC. Granted, these are only three specimens out of thousands that they must sell, but if this was completely chance rather than a trend, it's odd that I would get all three.
Now with all of that said, I like this knife.
The main problems that I have with it are cosmetic: not worth sending it in. I am curious, however, as to who else is seeing these issues. The sheath, while I would prefer more retention, is very slick. I really like the Snody method of attaching it to a chain. This design goes the extra mile to prevent the knife from flipping around on its chain.
Retention, is of course, spectacular. I don't know whether it was intended in the design or not, but you can actually get your pinky into the bottom of the skeletonized handle for an even more solid grip. Well, at least I can. Maybe your fingers are too thick to do so. But this grip allows me not only the most solid hold possible, but it turns the butt of the knife into a good striking point.
The SPOT fills the hand better than La Griffe, but size isn't that different as you can see in the picture. This knife is another great work in ergonomics by Spyderco. The way it rides in its sheath though does present a larger overall package than does La Griffe.
The spine is serrated from the micarta scales up to the middle of the second decorative hole. This is a nice feature but I would have rather seen that production effort go into the overall fit and finish.
The decorate holes are nice but best I can tell, the sheath doesn't utilize them. This is a big mistake in my opinion. The great thing about kydex is that it can grab on to any aspect of a knife. I would have loved to have seen tiny dimples inside the sheath that fit into the decorative holes. This would allow a better fit of the sheath and might eliminate my rattling problems.
The SPOT is ambidextrous and works in a forward or reverse grip. The inward cant of the blade allows for increased cutting efficiency and the tip really rips through stuff. I like this blade shape but for a knife this size I'm not sure it's any better (or even as good) as a good wharncliffe or slight hawksbill (such as La Griffe). A big benefit of this shape though is the fact that you have a belly to work with (however small) but still a good tip for ripping. This puts the SPOT miles ahead of La Griffe in the utility realm but that's not really what these knives were said to be designed for. Still, I can see myself using this in the future for small, around the house chores.
Like I said, I really like the knife, and it has replaced my 2002 La Griffe as my neck knife EDC (at least for now). I always thought it would be a cold day in hell, however, when an Emerson would have fit and finish miles beyond that of a Spyderco. Spyderco needs to iron out these annoyances or at least drop the price of the knife somewhat. Perhaps I'm being unrealistic, however. After all, I have no idea how much this thing would cost in raw materials, much less with production. Still, it's questionable why the Emerson La Griffe with 154CM steel and Black Oxide finish retails for $71.95 while the SPOT with AUS-6 steel and a bead blast finish retails for $69.95. I bought the Micarta model (which retails for $109.95), and I'd do so again, but given the fact that they cost about the same, you could never get me to buy the AUS-6 SPOT over La Griffe.
Here are some pics to illustrate all that I touched on in this short writeup. Please excuse Tripod's pop-up banners: that is the price I must pay for free hosting.
Great review! Thanks, TOTC!
I just wish neck knives were allowed in California. Alas, no concealed fixed blades allowed here, regardless of length. :(
Johnny
Thanks, Johnny. Neck knives are a gray area here in MD, so I'll just watch my butt.
For those interested, Pachucko pointed out to me that the problems present in my SPOT were brought up by others on the Spyderco company forum:
http://www.spyderco.com/forum/topic...Spot.&forum_id=7&topic_id=6259&M=False&S=True
Apparently, they're all coming like this :barf: :barf: :barf:
I seriously hope Spyderco gets this ironed out soon. It's really ridiculous for people to pay this much for a knife that has a section that's completely unfinished.
Maybe it's deliberate. Look at the logic: You grab your neck knife in an emergency defense situation. You use your demonstrated grip where your pinky is inside the handle. In an instant, your delicate pinky skin chafes. You remember you paid big $$$ for the micarta version, and you get angry all over again. How could they finish the knife like this?! You then *channel* this anger towards your assailant. Voila! Increased defensive energy! ;)
Johnny
Could you tell me a little more about this? I guess it falls under the concealed weapon category, right?
Oh, one more thing, great review. The pictures in your link have made me all excited about neck knives again.
Johnny,
You're right, Spyderco has found function even in lack of form!
AlphalphaPB,
MD has a catch-all in the statutes that says we can't carry any "dangerous or deadly weapons" but it doesn't go too far to name what these are exactly. It lists a few and then just says, "any others." "Penknives without switchblades" are exempt which covers folders as long as you aren't being an ass. If the cops don't like you, however, your innocent folder becomes a deadly weapon.
There is a clause in our favor, however, that says that if we carry a deadly weapon (besides a gun) in reasonable fear of danger then we are not guilty of any crime. It is up to a jury whether or not our fear was reasonable as was our choice of weapon.
Basically, fixed blades aren't specifically outlawed (except for daggers, etc) but they don't seem exempt from the "deadly weapons" designation either. It's a fine line and not one that I want to challenge so I keep my nose clean.
Here's the actual text with some case law quotes: http://pweb.netcom.com/~brlevine/md.txt
TOC
Good review and thanks for posting the link on the Spyderco forum. :) As you saw from the the posts there, the finish problem on the Micarta scales is not totally isolated. Those who have handled the SPOT, IMO, so far agree with your evaluation of its function, form, and ergonomic fit. Good view on the stability of the sheath also!
I have to agree on most of your comments regarding finish and agree also that the ergos and functions of the outweigh this cosmetic defect. Sal's answer regarding finish on the Spydie Forum seemed defensive, IMO. None of us however have knocked the excellent design and function though and I, for one, will buy additional Micarta SPOTs for users while keeping the "Collectors" version pristinely marred (nice oxymoron). The emory cloth will have its first taste of Spydie Micarta here. Many of us Spyderco fans feel that although small, the defect does not give us the overall quality we've come to expect from Golden and should be adressed for future production. Again, my opinion, but these are the best neck knives out there. The SS model is fit, finish, and function "spot on". And I agree, a better steel like VG-10 would've been nice and may have kept blank machining costs lower between the two models.
Stay safe! Stay sharp!
Hi guys. Thanx for the great review. I think I am gonna have to go and get a SPOT this week. Just to answer the concealed knife thing and the ?'s about MD. I am proud to be working LE at Andrews AFB in beautiful PG County:barf: . Secret joke for all us MD'ers :-). Anywho there in nothing about concealed knives per se. It is all about concealed "Weapons". Well what were you doing that led an LEO to not only see you wearing this SPOT or other neck knife? And without grounds, what am I doing searching you to begin with? If I am to charge you with carrying a concealed weapon I need to have a good reason. I have caught people doing a plethera of things, and some have had pocket knives in thier possesion at the time, however if the offense in question has nothing to do with some type of assault or other crime that would need you to use your knife as a "Fruit if the crime", as in using it as a prying tool or something. Anyhow I hope that helps.
Great review, as always TOTC.
By the way, how did you like the Spyderwrench you came across several months back? I was thinking of getting one soon, but would appriciate your imput first. Thanks
Per USAFP comments on the need for cause in searches. The US Supreme Court severely restricted American's personal liberty concerning searches about 2 years ago. LEO no longer need "probable cause" for a search. They can search to satisfy their own need for safety. For example, on a simple speeding stop, cop can now search you before you get in his car for the lecture or breath-test. This is strictly based upon the cop's need to protect his personal safety. Cop can also search you based upon a simple street stop for questions if he feels a need based upon personal safety. There is no need for you to be violent, no need for any suspicious bulges, etc. Not all LEO exercise this additional power, but unfortunately the ones that are hard asses usually love this new wrinkle.
My take, you still have to be stopped for a reason, but there is no need for a very big reason to search you. I know this from personal experience. A SPOT is marketed as a weapon. It's beneath your shirt. Easy collar for concealed weapon...no need to show intent.
Hi Think, Thanx for the detailed report on the new SPOT. And thanx for the post on the Spyderco forums.
As much as I dislike hearing about problems or imperfections, I always appreciate hearing the truth. Truth still is the biggest circle.
Obviously we have a few things that have to be improved on the model. The unfinished inside portion of the skeletonized handle is the first most obvious problem, and has been mentioned by others in the forums. We are currently working on this both in Golden and in Japan. As much as I dislike letting imperfect pieces go through, it does happen. We are currently finishing the inside of the handle of the pieces here and those being made in Japan.
The holes in the blade were added to reduce weight and they are sort of a “signature” on the design. We planned to use them in part of the “grip” for the Kydex, but this is still being developed.
You guys are hard taskmasters, but it is you that we are tying to serve. So I still have to thank you for your keen eyes.
Java. “I’M NOT BEING DEFENSIVE!. heh, heh, just kidding. Sorry if I appeared that way. I’ll have to look more closely. I wouldn’t want to be defensive. That is a condition that impairs hearing and doesn’t serve.
sal
Originally posted by Sal Glesser
The unfinished inside portion of the skeletonized handle is the first most obvious problem, and has been mentioned by others in the forums. We are currently working on this both in Golden and in Japan. ... We are currently finishing the inside of the handle of the pieces here and those being made in Japan.
Which brings the question, When will the VG-10 model with the additional finishing be available for those of us who intend to wait until the improvements are made?
Thanks guys for the further legal opinions/facts.
Ranger757,
While the Spyderench rates high on the gadget factor, it's not as practical as I'd like it to be. I don't like the fact that there are so many pieces to lose. Just using it around the house I've had problems dropping parts. If I had been using it outdoors or in a more cluttered environment, those pieces might be gone for good.
Sal,
I really appreciate the response and I'm glad to hear that you are working on this. It's good to see that Spyderco still listens to the customers.
Update:
This thing is going in to Spyderco.
The sheath was loose when it first arrived but now it's even worse. Yesterday I was able to get it to pop out of its sheath from bouncing up and down in its chain. Not just once mind you, these results are repeatable.
I see a design flaw in the sheath:
If the knife is pulled straight down, there is an ok level of retention. If there is any lateral pressure towards the edge, however, it takes almost no force to unsheath the knife. The way the sheath is molded, this allows the blade to simply leverage itself out and fall.
It's hard to put this into words but I'll try and post some pics later to show what I mean.
It's so bad that you can hold the sheath in your hand and flick your wrist slightly and the knife goes flying out. I've never had a kydex sheath do this before, especially not on a neck knife.
TOTF,
Yikes...that doesn't look good. Let us know how and if the problem gets corrected.
By the way, Thanks for the info on the Spyderwrench. :)
Dennis,
I sent the SPOT in and shortly thereafter talked to Mike (@ Warranty & Repair) on the phone. He told me that Spyderco is reworking the SPOT sheath and that he would either send me something of equal value to the SPOT right then, or I could wait 'til the new sheath for the SPOT comes out. I told him I'd wait and he said I should call every once in a while to check in on the status. Speaking of which, I should give him a call about that.
Waiting is no fun, but they're making this right for me so I'm not complaining, especially considering the fact that before I sent it in, I unsuccessfully tried to remold the kydex myself.
If the Ronin or the Dodo come out before the SPOT is reworked, I might just ask for one of those instead and then re-purchase the SPOT at a later date.
The last I heard, which was a few days ago, the sheaths where still being worked on. You might want to ask on the SPyderco forum.
A noted and highly respected sheathmaker from around these forums is allegedly helping out with these sheath issues. You can guarantee he'll get it straightened out soonest...
