- Aug 2, 2010
I have been curious about this for a while now.
Is it better to simply re-quench/harden 15n20 that came from bandsaw blades, or should they be thermal cycled before quenching?
I'm also wonder what you guys have experienced as being a good hardness/temper temperature for kitchen knives as well as for general utility knives, assuming full hardness has been achieved.
I still have yet to use any 15n20 as a mono steel blade of for the cutting edge in anything laminated and I'm about to take advantage of the thinness and width of the steel by making a kitchen knife to start with.
FWIW, I am using the 15n20 'sheets' that I got from JT here on the forum.
Also, I guess this falls into the same question as above but more in general. Let's say you heat treat a blade and everything about the heat treat and grain structure is sound, except when tempering you accidentally over-temper it and so it needs to be re-hardened. Does the blade (steel) really need to be thermal cycled again before re-quenching?
I feel like I learned the answer to this some years ago but since I haven't had to apply it at all, it's been pretty much been lost from my memory lol. I believe I remember some makers saying that it needs to be completely re-done, as in re-normalized, thermal cycled, and quenched.
Thanks in advance.
~Paul
My YT Channel
Lsubslimed
... (It's been a few years since my last upload)
Thanks in advance.
~Paul
My YT Channel
Lsubslimed
