Should I be worried about "flattening" my edge/belly when sharpening?
When I'm sharpening I seem to notice that I sharpen the belly or center of my edge faster than the heel or tip. Should I be worried about grinding away steel faster in the middle and flattening my edge/killing the belly of my blade? I have a sense that as I reprofile my 801, I'm ending up with less of a curved edge and more of a straight edge.
The 'belly' of the blade almost always sharpens up quicker; at least it does for me anyway. The key is to watch the edge in all sections, and shift your focus to areas that need more work, instead of making repeated sweeping strokes along the full length of the edge. The belly on most blades will almost always be thinner steel, so it'll grind down more quickly. This is compounded by the small contact area with the stone in the belly, which amplifies the perceived change in edge profile as you continue to grind. It can definitely flatten out, if not paying attention as you work. The very tip and the heel of the blade are the areas that usually take the longest to apex, and therefore need more attention. If using full sweeping strokes along the full length, pressure used in the belly area should at least be very, very light as you 'skim' over it. The flatter mid-section aft of the 'belly' can usually tolerate some more grinding, but also sharpens up pretty fast, leaving the heel and very tip of the blade as the areas needing additional work.
David
If you use a full sweep, is entirely possible you're flattening out the belly a bit. Working in sections can fix this, or as David mentions you should use less force when working the belly. Even if you normally work in full sweeps, it helps to occasionally focus on the heel as it has that much more surface area.
Yes with HH. I like the working in sections part. Not watching or less experienced sharpeners often do grind the belly away. The straight blade portion is easier than the belly and I find it necessary to
change the angle slightly when I move to the belly. By lifting the handle. Check it often to note the progress. DM
