Should I give the CS Kudu a second chance???
Hi there... I cannot explain it.
I like big blades just because i'm convinced of its effectiveness.
So i see that cheap folder and it is like a love at first sight.:eek: No rust, good lock, interesting look, FFG long blade.
Then you see all the negative sides. Big, noisy because of the ring, soft steel, no clip, hard to open and close.
So i ended up giving mine to a friend.
Now i see that same knife again and against all reasons i can say... i like it.
Help...
Take it!!! I have one and I am happy with it in my EDC bag!!! Great knife to cut tomatoes and other vegetables for my lunch!!! I have many others more expensive knives like spyderco persian and bench 710 but I carry my KUDU!!!
Its a decent knife, personally i keep mine in my BOB along with a mora 612 and Buck 110. but for pocket carry carry it tip down and add a larger key ring. the key ring catches the edge of the pocket and holds on pretty well, aside from that try buying one of those add-on thumb studs or make your own, if its too hard to open take the blade out and file/dremel off the bumps. I also use it in a constant saber grip with my thumb through the larger key ring, works decently well to prevent your hand from sliding up
hope that helps
You CAN one-handed open them with practice, and I fixed the noise factor by replacing the ring with a paracord loop.
