I own both, but only purchased the RS recently, so I cannot yet comment on which I prefer in actual use. My initial impressions of them are that the B1 is prettier and a better slicer with more blade to it; but the RS feels much better in my hand, is more comfortable to use, and has a more robust blade for harder use.
This is an unfortunate pattern i have experienced with the B1. I purchased it based on rave reviews and the Bluntruth4U videos... But for heavy wood use, I have found my Cattaraugus 225Q both more comfortable and more efficient, and the same goes for the RMD I purchased later (my first entry into Bussekin). So I relegated the B1 to lighter woods duty and hunting ... but I purchased an HRLM to match the RMD and it again out-performs the B1 at everything except deep slicing and looks! Well, my addiction to swamp rats keeps pushing when something appeals, and i resisted buying the Solution until I got a good deal on the exchange for a match to my other rats... NOT sorry i made the purchase! I would not consider the RS a proper match to the B1 based on dimensions, etc. - the HRLM is closer - but for more general utility and hard use not requiring a longer blade, the RS will better fit the bill. You really have to handle a rat to appreciate the thought that went into the design. So as much as I love the BRKT and hesitate to let it go, it doesn't see as much use now that I'm in the swamp - just not as comfortable and not as robust, poorly designed imho.
You can still get the RS from the factory, otherwise they show up on the exchange for a small discount from time-to-time, you just wait for the color configuration you want, and they are an excellent entry Bussekin at ~$100. At that price, don't hesitate. If the swamp discontinues them, they'll only go up in value, even used, not that you'll want to sell it. The RS will replace an puukko-style knife you own, the only downsides being heavier weight and a perhaps lower slicing efficiency (due to more robust, stronger edge). If you want a Bussekin with a longer blade for heavier wood/"survival" use, both the RatManDu and SYKCO 511 are still available from the factory or can be picked up on the exchange. The 511 is actually cheaper than the factory RS, but on the exchange they're about equal, the RMD only reasonably more expensive.
Get the Solution. If you don't like it after handling/trying it out, return or resell it. Eitherway, you owe it to yourself to try it out. :thumbup:
