Gryffin said:
You merely persist in thinking that those "sharpened prybars" should be treated differently from all other folding knives.
Yes, I would expect a folder with a much thicker and more obtusely ground blade to have a wider scope of work the same as I would a fixed blade of similar design. That is certainly how they are promoted. Similar with locks, not all locking knives have the same scope of work, some are significantly stronger and more secure than others.
Any knife locking mechanism that is capable of being unlocked, is also capable of being unlocked accidentally, and then folding unexpectedly; No knife is perfectly secure in real-world usage.
The same is true of any aspect of knife use, what is important is the consistency of the design in terms of the intended scope of work. It makes little sense to put a hugely robust blade on a lock which is easily released under light impacts, torques and other dynamic cutting.
Looks like my original statement holds up pretty well: locking folders are a compromise between slipjoints and fixed blades.
No, that is far too simplistic a point of view, there are slip joints which are more secure than locking folders, several people have made this point because various lock types once released have the blade collapse with no resistance and the effort required to cause the initial release them can be far less than required to close a slip joint with a stiff action, and there are lots of folders which are capable of a wider scope of work than various fixed blades.
In the case of a heavy-duty folder like the Fulcrum, it can unlock accidentally (eg., white-knuckling the lock under stress).
No it can't, the back lock has a cross bolt.
Once again, Cliff, you're confusing strength with reliability.
You may want to check the origional post :
"On another forum we were discussing whether locking knives should be trusted or if, in fact, they were designed to do things non-locking knives did."
The answer is yes, many are specifically promoted for uses which are beyond the scope of work of slip joints because such uses intentionally load the blade so as to directly oppose the lock. The lock is not simply a safety device, it is part of the design to allow the knife to do things which can not be done with out the lock.
In terms of strength vs security, both have the same consequence when it comes to user safety, both a blade breaking dramatically or a lock releasing pose a large risk to the user and thus both limit scope of work. Some releases may also functionally damage the lock, obviously a blade break damages the knife.
I can be a lot more rigerous with the Fulcrum and use it for a much wider scope of work than the Deerhunter because any force which would cause the Fulcrum to unlock/release would have long broken the Deerhunter, it is made to be used for other things and the lock is integral to this design.
Most quality locks should break before they will accidently release, if they do otherwise they are improperly designed because the strength is irrelevant, they are not then functioning as a lock, Steve Harvey made this point years ago.
-Cliff
