- Apr 3, 2010
RAT RC5 is a stout thick, heavy, 5" chopper and baton blade with a very nice sheath. It is crafted in 1095 steel 1/4" thick blade with a full tang and full flat grind. Micarta Handle and a protruding pommel tang. 16oz! Rat has an excellent warranty comparable of to the Swamp Rat.
vs
Swamp Rat RatManDu (RMD) is a super sharp stay sharp SR-101 Steel 5+" Blade that is 3/16" Thick with a protruding tang with lanyard hole, Micarta Handle, Same warranty coverage as RAT no sheath (but blackhawk and others make excellent sheaths options for this blade). No known weight spec I could find.
vs
Fallkniven S1 VG-10 5+" blade with a .2" thick blade, Thermorun checkered handle, zytel sheath which (I have an A1) I think it is just ok but is light and small. The Blade is probably the lightest of the bunch 6.7 oz and has a flat protruding tang. This blade I would think would be the packers/hikers best friend! The weight is right the steel is stainless and the sheath as far as it is, is small. But it probably lacks the chopping and precise whittling because of the grip limitations more so compared to the grip youcan put on the RMD but I am yet to prove that. As for Warranty...nowhere near the others.
I believe all these blades are excellent however I only have one the RC5 (an A1 which is close). As for My RC5 I can say the handle is big and boxy but seems to work, I have not felt hot spots using it. My grip style (Depending on the task whether chopping or slashing) works well however from what I have seen of the RMD is the semi circle cut near the finger guard on the blade seems to offer pluses and a minuses. Chopping and batonning probably wouldnt be as good...for one not as much blade surface nor I believe (this is a guess based on blade thickness) weight...the RMD should be lighter leaving the S1 at a chopping 3rd place but yet again I cannot confirm. As for the grip shapes, I like the RMD better (never held it but it looks less boxy and slightly smaller). As for the S1 it has the same checker pattern as the A1 so it would feel nearly the same. But I believe the S1 would be better in wet hands than both. Most of us dont try to handle or use our knives when our hands are wet. But sweat is a different unpreventable situation for some. As for whittling wood and precise bushcraft the S1 and even the RMD blade should be less clumsy due to weight and blade design and more so grip and grind. Sure rough shaving the RC5 is a hungry eater but fine detail...I am not sure. As for Steel...they are all good but some have limitations. The SR-101 is a steel that holds its edge better if not the best of all steels including INFI. VG-10 is the best all around elements friend blade...no rust! And the 1095 is the easiest to maintain.
So sound off on your Pick and why. And certain offer your experience if you have all or even any of these blades. I only have the RC5 and an A1...which is very close to the S1 but is still different. Let me know. I think these are the cream of the crop of the 5" pack. I left out the BK2 because it has an inferior handle...nowhere near the others...I know you can add the Micarta but then you up the cost to these blade class in which I believe all to be better.
vs
vs
