How do I tell which one I have. I see a hole in the butt piece by shining a light in it but have not taken it apart yet. Thanks for the reply.There were a couple of different spring designs for the LB5 over the years. One was a butt piece with a spring rod inserted into it, the other was an integral spring and butt piece. You'd have to know which one came with your knife in order to replace it.
Eric
Not sure if it will work. Thanks to a few replies from some great people on here I guess there are a few variations. I will keep you posted and thanks for the offer. Or if you wanted to send it up I can try. I appreciate your response.
Thanks for the info, I was afraid it would be to thick but wasn't sure. I've not had an LB5 in hand just the LB7 and an LB3 I have. Wasn't sure where the LB5 fell in the range really I know the LB3 is small because I keep one in place of the missing stone in my Uncle Henry large pro hunter sheath.David an LB-7 flyspring won't fit an LB-5, it's too thick. The LB-7 spring is about .120 thick and the LB-5 is about .095 thick.
Marc I have some of the integral sandwiched springs but none of the two piece flyspring/butt piece models that it sounds like you need. You might have some luck here:
https://www.allaboutpocketknives.com/knife_forum/viewforum.php?f=54
Also I believe I might have some .095 spring wire that you could use. You'd have to trim it a bit to get the proper length but that's easy to do with a lockback as you can basically assemble it all minus one side to see how everything fits.
Eric
