Shure SE310 earphones
Daniel Koster
www.kosterknives.com
Picked up a set of these on e-prey for a good price (NIB - open box)
http://www.shure.com/PersonalAudio/Products/Earphones/SEModels/us_pa_SE310_content
The prime reason I got these...was to be able to listen to music and audiobooks while working in a noisy shop.
The "muting" by these earphones is incredible. :thumbup:
If you get them sealed correctly (takes just a couple seconds) you literally cut off the world around you.
I had some sound-isolating headphones...and they did a decent job of cutting down the noise...but I still had to turn the volume up.
With these, I have the volume at a much lower level. So, even though the earphones leave a distinct "feeling" in your ears for a minute or so after extended listening...the wear-n-tear on your "drums" is much less since the actual dB is within normal levels.
If you're considering a set of high-end audiophile earphones...Shure is the way to go. :thumbup:
Dan
And if you wear a set of sound-blocking earmuffs on top of them, then you're really set for listening to music in loud environments.
I used to do that....sound-blocking "gun range" muffs over earphones. Works great. But these really do block outside sound so well...I don't need the muffs. Plus the audio quality is very nice.
I havent seen these before, but I have E3Cs that I even use while mowing the lawn, without them I always wear earmuffs. They really do a great job of blocking noise.
I have some imposter shures Phillips SHE-9501 and they work almost as good as the e2c (i think) for a fraction of the cost. People dont know what they are missing with sound isolating earphones.
