- Dec 30, 2018
I would like to purchase several different powders for lapping. Anybody sell small quantities of different grits?
Both are on the tough, least friable end of the spectrum.Here is some 60 grit SiC:
https://www.edgeproinc.com/sharpening-accessories/60-grit-silicon-carbide-p35.html
240 grit AlOx for DM stones:
https://www.edgeproinc.com/sharpening-accessories/240-grit-aluminum-oxide-powder-p71.html
Who sells it and has a wide selection of top quality grits?Not only are there different qualities but more importantly there are many different grades depending on your needs. Do you want a tough crystal that resists breaking down or do you want one that breaks down easily, ie friable? For lapping I like black sic as it is the tough vs friable variety. Even it breaks down fast so your 60 grit drops down to several hundred grit after a minute of lapping.
The Washington Mills website has a lot of info on many different sic powders.
I only know where to get it in 50lb boxes or bags but if you call them they may know of a company that buys from them and sells smaller amounts. Or if you can tell a good enough story they will send you samples. 15 years ago KC Abrasives sent me 6 each 2lb samples of Alox and Sic for free after calling them up. They are another good supplier but I think they buy their feedstock and have a smaller offering. Washington Mills makes their feed stock and have a much larger offering, they are also much, much bigger and you have to talk to a rep, vs someone at the company that knows what they are talking about. Whenever I have called KC Abrasives I have either talked to the owner or his son.Who sells it and has a wide selection of top quality grits?
Anything from resin bond polishing pads for polishing stone to lapping many different things flat or to size. It can be really handy stuff to have around.Diemaker, it sounds like you have experience with the different SICs grit types, what are your uses?
You posted a good link to Washington Mills that has good info. But since Washington Mills is a manufacture that sells to distributors, where are good places to purchase SIC grain for the average person?I only know where to get it in 50lb boxes or bags but if you call them they may know of a company that buys from them and sells smaller amounts. Or if you can tell a good enough story they will send you samples. 15 years ago KC Abrasives sent me 6 each 2lb samples of Alox and Sic for free after calling them up. They are another good supplier but I think they buy their feedstock and have a smaller offering. Washington Mills makes their feed stock and have a much larger offering, they are also much, much bigger and you have to talk to a rep, vs someone at the company that knows what they are talking about. Whenever I have called KC Abrasives I have either talked to the owner or his son.
It depends on what you are lapping, it's not just for stones.More than you would probably use in a lifetime of lapping and its only 27 bucks for the whole set. Individually they are about 5 bucks each.
