- Jul 2, 2000
I bought an Emerson CQC-7A bead blast not too long ago. I really love everything about this knife, except the finish. I thought it would be prone to rust (yes I take care of my knives) due to the deep bead blast. My local knife shop recommended using a super eraser to clean up the finish. I was skeptical at first but the salesman assured me it was easy to use without making your blade look like a scratch fest. The super eraser is like an eraser and a fine grit sand paper, in one. After field stripping my knife, I made an initial pass over the blade with the odd piece of rubber. WOW what a difference! After about 5 min. work the blade looked more like a frost finish than anything else. The finish was smoother and more uniform too. The trick is, stay with the grain of the blade ( no circles ). Now my CQC-7A looks like it came from the factory with frost instead of that deep Emerson bead blast. BTW/ The Emerson logo doesn't fade at all, it's in the steel pretty good. you could rub a little or a lot depending on the effect you are looking for. I was also told that it works on BT, but I have yet to try that. Take it from someone who has no finishing skill whatsoever. It's easy. Check with your local shop, they might know where to get one if they don't already have it. BTW/ It also is great for cleaning ceramic sharpeners, and rust.
