As promised in another thread, ran a side-by-side sharpening test of the SharpPebble 400/1000 whetstone (confirmed with their service team as being equal to about 320/500 ANSI grits) with the Baryonyx Arctic Fox (400 ANSI). The goal was to observe the sharpness and edge finish the SP 500 grit could produce compared to the AF.
Approach:
Sharpening setup
Both knives after profiling on the Crystolon coarse:
Both knives after sharpening on the AF and the SP
Approach:
- Had 2 copies of the Schrade SCH221BK folder, which uses a soft stainless (9Cr18MoV ).
- Profiled the edges to about 12 dps as pictured below on a Norton Crystolon 100 grit SiC stone. Placed a caliper midpoint on each edge where the bevel met the shoulder, one was 0.029", the other 0.027". Close enough for this freehander.
- Sharpened the knife labeled "AF" on the AF stone, about 35 strokes per side.
- Sharpened the other knife on the SP stone (500 grit side), about 35 strokes per side.
- No stropping or other refinement was done other than a few light passes on a clean stone with each knife to deburr. Obviously I could've done a lot more to eke more sharpness from each blade, including more work on the stones, and stropping.
- Visible finish. Very close. The SP finish is slightly more coarse under inspection with a 30x magnifier. It is not a large difference and does not show easily in my cell phone pics.
- Sharpness tests. Identical. Both knives performed all the following tests:
- 3 finger sticky on the edge.
- Thumbnail test at heel, midpoint, belly, tip.
- Shave arm hair with moderate friction.
- Shear-cut thin receipt paper.
- Thin catalog paper (push/draw cut with grain, shear-cut cross grain, push-cut cross grain, both knives struggled to draw cut cross grain).
- ETA: both knives also passed @wootzblade sharpness chart test to shave curls off the surface of printer paper. The chart suggests this indicates an apex width in the range of 0.25 micron.
- After the above tests for curiosity: I stropped one knife on 1 micron cbn compound. This noticeably improved the cross-grain cutting ability and now this knife passed that test too.
Sharpening setup
