The screw on the side of the handle. Near the blade.ya talking the pivot? just tighten it back up. use blue locktite to keep it from coming loose again.
yeah sounds like the pivot screw. figure out what size torx it is or whatever fastener type and get right tool and some blue locktite and remove it coat it with locktite and retighten it to position where blade moves freely and no play and let it sit and cure for a bit. just follow directions.The screw on the side of the handle. Near the blade.
see what happens when ya leave for a bit Chris, they all come out of the woodworkJeesh what is it today.
Memes in GKD….the WnC must be getting boring!
Bolt comes loose. Wheel falls off. What a horrible design.Side screw becomes loose - The blade becomes loose.. What a horrible design
Side screw .... tighten .... using screwdriver .... tighten helps ...... blade no-no loose .... no-no horrible design will beSide screw becomes loose - The blade becomes loose.. What a horrible design
