Hi,
As a SxS shooter and collector, I will tell that they are an expensive taste to acquire.
I have owned a Stoeger 12ga. Uplander. It was meant for a knock-around/loaner gun. I had trouble with the safety coming on under recoil. This has been a knock against Stoegers SxSs. From the reading I've done, it's a somewhat common complaint. It can be fixed, though it may cost almost as much as the gun. I replaced it with a Stoeger Condor O/U that has been faultless in it's role as a loner/beater.
A couple of observations on the Stoeger SxSs. They are Brazilian made by by Gaucha-IGA. It is best to consider these guns as disposable if they break. Spare parts can be difficult to obtain if not impossible to get. They are not high volume shooting guns. Don't expect them to last for 10,000 rounds. The guns themselves are "boxy" and chunky in the hands. They do not point naturally or swing well. And like most of the cheaper SxSs, they are needlessly heavy. Particularly in the smaller gauges. Due to the manufacturers building 20ga and smaller gauges on the same 12ga frame size.
Stay away from single selective/non-selective triggers in cheaper SxSs. They are pretty complicated mechanisms and require expert fitting. Even then, they are more prone to breakage than double triggers. Even on 6 figure bespoke guns. Ejectors too are a bit problematic on SxSs. So I tend to stay with extractors on them.
I have owned a couple of hammer guns. I still have a replica 12ga muzzle-loader SxS. And I owned an older Husqvarna for a while. Neither have safeties. Don't know about the current new offerings though.
If you buy a Stoeger, just remember that you may get a good gun, or you may not. I've owned two, one is a good shotgun, one failed and had to be disposed of. I think as an inexpensive, beater and low volume shooter, they offer a better value than some of the older inexpensive shotguns. Mostly because they can digest steel shot. And for field use on public land, you may as well resign yourself to shooting steel. Those older guns like the Stevens 311s aren't recommended for use with steel shot.
dalee
