Thank you for the kind words, gentlemen. BushMonkey mentioned clean lines, to me that is a very high compliment and I appreciate it!
How many coats of Danish Oil did you rub in? I have been wanting to try Danish oil on a knife.
I honestly don't know, probably around a dozen. It takes a couple-three days or more to get it all in there, depending on the wood of course. The first 3-4 applications soak in pretty quickly, when they are just about dry to the touch I clean off the wood with 0000 steel wool. Wipe off any oil/metal residue and repeat. I do take the wood to its final dimensions and sand to 400 grit before oiling. At the last stage of sanding I lightly moisten the wood, let it dry then sand lightly again, repeating this until the grain no longer raises. This is a furniture maker's "trick" that helps you get a silky smooth surface.
After that it's a matter of just wiping a little more oil on and going after it gently with steel wool again, until the wood just doesn't want to absorb anymore. The last couple times I don't even use steel wool, I just burnish with denim or heavy cotton material. Danish oil is available with varying amounts of stain in it, but I always use the clear kind, it shows the original color best. You end up with a finish that's very smooth and warm to the touch, shows off the natural grain and figure, and resists dirt and water fairly well. When it gets yucky you can freshen it up with 0000 steel wool and a few drops of Danish oil (or lemon oil, tung oil, any natural oil you have on hand in a pinch.)
None of this is absolutely necessary, you could just sand to 220, slap on a couple coats of oil and buff it off, most woods will look pretty decent that way. But I feel the extra attention is worth it to get the nice feel and help insure the wood is fully sealed.
Hand-rubbed oil finishes are generally not super glossy, and are not THE most durable finish available. As with "simple" carbon steels, I liken them to Grandpa's old deer rifle... if given a moderate amount of care and used with common sense, it can be passed on for generations :thumbup:
Thanks for the questions, and don't be shy. I'm happy to share what I do know and I will likely learn more in the process!
