Siezed Tool Problem
I previously described my satisfaction with my Providence Cutlery Campmaster in the Traditional Knives Forum. Since then, I have started to run into problems with it. The bottle opener tool is practically stuck in the closed position. It is possible to opern, but it is not comfortable, and require a lever to accomplish. I lubricaterd it in hope of easing it up, and that is not helpful. Any suggestions?
I didn't read the other post and not clear of the problem here. was the tool easy to open in the begginning? Is is getting rust in the joint? Can you adjust the tightness or disassemble the knife to clean and lube? Can you post a link to the other post if relevant?
Original Thread:
http://www.bladeforums.com/forums/showthread.php?t=397636
Doesn't look like it will be to simple to tear apart, unless somebody could give me some direction. I have only carried it a few times so I'm not too worried about dirt or anything being in the workings. Used to open as easily as the other tools, and now it's a struggle to get it to move. Once open, it's not too bad so long as I don't close it (it moves in and out of position with normal force). I was able to get some contact info for the company on another forum. It is a cheap (but decent quality USA made knife). Maybe I can get some help out of them? Well I also have a second unused one that I've been saving for a rainy day, and I'll probably be able to get another (or few) in the future. Not horribly worried about it, but I would prefer to get this baby working right again.
I treated it well, but I'll check the joint for rust. You never know. The tools originally opened with normal force, and know is near impossible (not my doing).
I see.
The parts are riveted together so it would be a 15-20 minute job to take it apart, clean, hone and reassemble, if you had the tools and material on hand. If it was a $20 knife that may be worthwhile.
A lot of the old Colonials and Imperials, even with stainless blades, have non-stainless steel liners and backsprings. The problem you are describing may have been caused by a little rust between the liners and springs. If you haven't done so already, you might try opening the blades and using some spray lube along the backsprings from the inside. Carefully using a nylon brush to scrub out any gunk on the outside of the backsprings with the blades half open will often help also.
