Bingo. WD40 is addictive for this very reason. Once you use it, you have to keep on using it. I prefer a less sticky solution, like Boeshield T-4 or Militec. Boeshield is pretty much my go-to lubricant for around the house type of stuff.When WD40 dries, it leaves a sticky residue that dirt loves. If it is frequently reapplied then it dissolves the old residue and washes out the dirt and all is fine for a while. Then we start again.
Oops, didn't notice this reply. If you wipe it down once, it doesn't attract dirt. Even if you don't wipe it down, I find that the waxiness repels dust, rather than attracting it.I must be getting sold a different Boeshield than you're getting. My cans leave a waxy residue.
GIRLYmann said:i did come across some past speculation that WD40 is primarily kerosene in a spray can?!
L. Richard said:I use the same lubrication for knives as I use for the rotary valves on my French horn: mineral oil or sewing machine oil, diluted to the desired viscosity with ultra-pure lamp oil (also called paraffin or kerosene, depending on where you live). It's cheap, works well, and there is no residue build-up.
vwb563 said:i sprayed silicone on my swiss army knife and it started melting the handle material. i wiped it off immediately but it still managed to do some damage.,,,VWB.
