My Pocket boys perfect-did you bend it?
No. I have even controlled the blade to see if it came bended. It is perfectly straight. And it is well fixed.
I have seen that if I push the blade with my fingers (or with the lower part of my handpalm) from anywhere further than 1/4 of the blade from the Grip, the tip of the blade will move/flex a bit (2-3mm) and will touch the rubber of the Grip. Sometimes less, just a scratch before going into the slot of the grip. But sometimes more, so to stay stuck with the teeth into the rubber on the border of the slot.
I have noticed that when I fold it, with the grip on my right hand and the blade on the left, I press a bit the grip toward the ground and pull the blade toward my head, if you know what I mean. I mean, not willingly. And just a bit. But a bit is enough.
If I am extremely careful this does not happen, but I can not be all the time very careful in the reality of my job when you have to maintain a big garden and you are paid pro hour and you must be fast.
If I take it / push it from the first 1/4, it almost always close perfectly. But it is not a natural thing for me, and it is also more difficult.
Spontaneously I take the blade from the half or 2/3 of the blade...
How do you close them?
Do you realize that Silky's are pull-saws? If you push against the blade you will certainly bend/break it....
Yes, I am aware of that. I am talking of folding/closing the saw, not of using it.
So, when I talk of pushing I refer to what I do after that I have unlocked the security mechanism, and I push on the back of the blade to make the blade go into the Grip.
Sorry but I cannot explain it much much better in English.
What I do it, I have the grip in my right hand, and I either take the blade with my fingers and push it into the grip, or I push with the lover part of my hand, to guide it into the slot inside the grip.
I suppose that a thicker and/or shorter blade will not flex so much, and will make my life easier.
So I am thinking about buying the Pocket 130 or the Gom 210.
I kind of feel that the gom is too big and heavy for me, I keep the saw in a sort of "pocket" in my work trousers. You know, I have an opening on one side for the folding rule, and another on the other side for the folding saw.
So the Superaccell is way to wide for this opening, and the gom is ok but I am afraid could be too big and heavy.
On the other hand it is nice to have a 210 for when I will go somewhere and have no chainsaw and I have to cut a thicker wood.
But in the 80% or more of my job I think the 130 should be ok...
Mumble mumble.
What do you guys suggest?
