If you think it out clearly, almost all lines will intersect somewhere UNLESS they are perfectly parallel to each other.
In this equation if you got a perfect number like x=27400 (which i got as well), then YOU MUST HAVE an intersect since you've already proven that:
y from 1st line=y from 2nd line (WHEN x=27400)
So all you need to put in is x in one of the line equations. You will get something like y=3760. IT MUST BE THE SAME FOR BOTH LINES. You can check it with both equations if you want to but that's not really necessary since you already equated the equations in the first step.
So the lines intersect at x=27400 and y=3760
Oh the joy of mathematics. I miss it sometimes. BTW i do use a graphing calculator but rarely use the graphing functions. Used to use it a bit but didn't really find it all that useful if you already know the functions. In this case it would be difficult to show since the intersect is so far away. You don't need one for this equation anyway. However, what i do like about my Sharp calculator is its equation editor. VEry useful feature. What you can do is write up all the long equations without calculating between steps and just plonk it down in the calculator in the last step. It even has division functions that look like division instead of using a slash (/). So you get equations on top of each other which is easier on the eye and avoids careless mistakes.
Quote from SHarp website:
"Sharp was the first to introduce a technology called Advanced Direct Algebraic Logic. D.A.L. is an innovation which allows students to enter the elements of an equation into a calculator in the exact order they appear in the textbook."
Damn this should be in gadgets and gear. It's just that i've been using the same sharp calculator for almost 8 years now and it's saved my butt a few times due to the equation editor. During my degree course finals i had like 5 minutes left for the last question which was kind of a big question you're supposed to do in 20-30 minutes but because i could leave the calculation to the end all i needed to do was write down one long equation so the lecturer could see the method and just the answer underneath. Aced that exam because of that.
