- Feb 20, 1999
I have been brazing guards on for several years with great results. What I don't like is sometimes there are pits and the grind down takes a lot of time. I decided to try silver-soldering and had no luck at it.
All sufaces were clean and fairly tight fitting. When I put the heat to it, it would not flow. I had to put so much heat on it that the "blue" ran up part of my blade wrecking my heat treat. I was using low temp. solder and flux. Any suggestions would be appreciated. I just want something easier than brazing, but also as strong.
