Simi Skinner/semiskinner/Nessmuk?
The first time I noticed the shape was when Loveless showed it as "Simi Skinner". I then saw a remarkably similar Morseth "Semiskinner". Then, more recently as a form of a "Nessmuk". All have about 3.5-inch blades with a slightly upswept curving blade with a decided point that appears to be centered as a definite tip. Loveless and Morseth versions have a decided finger guard. So it's not exactly a skinning shape, not exactly a drop point. The shape kind've appeals to me aesthetically but I don't understand where it would excel.
I will appreciate people who have used the blade on deer, elk, and other larger game animals to describe its utility or, in advertising lingo, its "unique selling feature". What lurks in my mind is that this is ideal and I've been blind to its incredible usefulness as a field tool. But ideal how?
A difference you will notice in hand is that the Loveless semi-skinner has a 1” wide blade while a Nessmuk will usually be wider than that and the “hump” in the blade is more pronounced leading to much more belly, they’re also usually around 5” in blade length as well, the Loveless pattern stays true to his Dropped Hunter size with a 3-3/8” blade, 8-1/4” OAL.
I have several semi-skinners made in the Loveless style and owned an original at one point as well and can say that it’s a great pattern to use as a field knife on animals. Will it do anything markedly different in those regards when compared to a regular drop point? Not really, but I do like the thinner belly and more acute tip that the semi-skinner affords, plus they look so damn nice. I haven’t used a Nessmuk knife that was in similar dimensions to the Loveless semi-skinner but I do own one and I prefer the semi-skinner and standard dropped hunter if I were going to pick one out to use for the day.
