Use forum search for wood finishing. Sometimes Google search works better if you just put in your terms and add bladeforum. You will want to sandback starting with 120 and sand up to 400+. Some finish even higher. Standard procedure would be to start wet sanding at 320 with your finishing oil. Leave the slury to dry for a minute or two and wipe off the excess. Sand to as high as you like, lower grit is grippier, higher grit is shinier. Build couple of coats on top with oil leaving to dry inbetween and wiping off the excess. Tru oil and Watco oil are recommended products. You can use any daenish oil, or if you want to go fully natural use tung oil but it will need to dry longer between the coats. You can hand or machine buff if you want it to be shiny. You can finish with a coat of wax.
Many things to do, it's just one of the things that everyone develops his one approach and process. The above will give good results.
Mineral oil was a shitty advice as it is a non drying oil. I don't even like it on my cutting boards, much less on knife handles.
