I am just getting started in making my own knives. Hopefully soone I will be able to order some steel and start grinding out some blades. I know that O1 and 440C are pretty much the standard steels to start with. At the moment i am leaning towards O1, so hopefully I can do the HT myself and save some money. Being a student I don't really have all that much money to spare. Another thing I like about O1 is that it is a good deal cheaper than 440C, and just strting I am sure I will make mistakes and ruin blades. I would much rather waste a piece of steel that cost me a few cents a foot than a few dollars a foot.
My question is on what I can use to get the O1 up to the correct temperature to harden. I have an old BBQ grill, but doubt that would do the trick unless I rig up some kind of blower. Would one of those MAPP torches do the trick? I have a propane torch, and an Oxy/MAPP torch. The propane alone won't get it hot enough, I know that. With the Oxy/MAPP rig the heat is concentrated in such a small area (meant for welding), that I doubt I could heat the whole blade enough. Another option I might have is using my home furnace, as I can open it up and stick the blade in there. Only problem with that is I don't really think oil quenching in my basement is the best idea.
I would also need to work whenever the burner decides to come on, and hope it stays on long enough to get the steel where I need it. I am guessing that a MAPP torch might be my best bet. Or if that wouldn't work then maybe building a cheap forge, are there plans in Goddard's $50 Knife shop? Been meaning to pick up that book for a while now. Thanks for your help.
