So I've been looking for a simple approach to maintain kitchen knives for family members who aren't into freehand sharpening, or even a guided system like Sharpmaker. Found an approach that seemed to work, would welcome comments or suggestions.
Things I'm interested to hear comments on:
- Set a new bevel at 12 dps, using Crystolon coarse. Plan to do this with each kitchen knife, so that they are all consistent and maintained the same way.
- Sharpen with this progression (tested sharpness using standard @wootzblade tests after each grit; each progression added noticeable sharpness).
- SiC 320
- SiC 500
- AlOx 1K
- AlOx 6K (only 5 light strokes per side, less than weight of knife).
- Cut a 16 dps micro-bevel using a 2200 mesh DMT ceramic rod, using an angle guide that mounts right on the rod. Showed the fam how to use this to maintain the micro.
- Note: Didn't bother stropping, it didn't seem useful as I was already getting the results I wanted.
- Is the above sharpening progression of 4 grits plus a micro-bevel on ceramic really necessary, or is there a way one could streamline, cut out one or two steps in the progression, and get equal results? If somebody knows a way, I'd love to hear it. I tried different techniques with each grit, trying to get max performance, but in the end, it was simpler to keep stepping up to a higher grit until it got where I wanted it to be.
- Is the 4 dps gap between the secondary edge and the micro too much? Would it noticeably improve cutting performance, or edge durability, if I brought them closer together and went with 12(secondary)/14(micro)?
- Is the ceramic rod the best option for maintaining the micro? Given the known issues with ceramics, would I be better off having them use an extra-fine grit diamond rod? Or, would it be better if I cut the micro on the last stone in my sequence, and then have them just use a quality smooth steel to maintain the micro?
