food grade mineral oil. that way if you peel an apple or cut any other food it wont hurt you.
For a Sypderco Persistence and a Delica with VG-10, any tricks to keep them rust proof or anything like that. I try to clean the blade by running it under a small bit of water and wiping it dry with a cloth. Good idea? Spray WD-40 on it?
Do you have a brand name that you use/recommend for mineral oil?
The easiest solution is to pick up some of the 'laxative' grade mineral oil in the pharmaceutical section of your local Walmart/drug store/grocery store. It's actually sold as an 'intestinal lubricant' (laxative) so, obviously, it's food safe.
Just don't DRINK too much of it...![]()
Clean & dry is most important. Even more so, if you're knife is exposed to saltwater or sweat on a regular basis. If you do feel the need to add protection to the blade, the mineral oil suggestion is good if you use the knife with food.
