Here is a method I like to use that maybe someone else can get some use out of. First you need 2 fired .22 magnum cases, some 3/32" rod and some 1/16" rod and some epoxy (colored if you like). Cut 2 pieces of 3/32" rod and 16 (if i remember correctly) pieces of 1/16" rod slightly longer than the case. Fill the case about 1/2 full of epoxy and insert the pins. Put the 3/32" in the middle and suround it with the 1/16" pins. Mash the pins in and the epoxy will be forced up between the pins. Watch out or the pins will back out because of the pressure inside the case so hold them for a few seconds. Wipe up all the gooey mess you made and let the epoxy cure. These fit perfectly in a 1/4" hole. Epoxy them in the scales and grind the ends off and you have "flower" mosaic pins that look real nice and you don't have to tell anyone that they only took you five minutes. I like to vary the pins using stainless, copper and brass rods. Hope this helps someone.
Leonard
"Hell hath no fury like a draft dodger scorned"
Leonard
