Skoda coil spring question.
The other week, I picked up a couple of brand new (VW) skoda coil springs.
Being the scavenger that I am, my first thoughts were knives.;)
After staightening the springs I done a quick test to see how they hardened etc. I made a very rough but thin chisel type end on one of them and quenched in water (I used a friend's forge as it's bigger than mine, but he had no oil at his:rolleyes::D) and then tempered them over the fire to a purple colour...not very scientific, but it was just to give me an idea of how they worked.
The end was ground to about the thickness of a bowie or camp knife, and then tested by cutting some 3/8" round and square mild steel bar. To my utter surprise, the edge wasn't damaged at all.
I then put it in the vice and proceeded to break it, the table lifted first and it took a good bit of pressure to snap it. The break looked like fine, light grey velvet.
Seems like some good stuff.:thumbup:
I appreciate that no one will haxe the VW/Skoda steel specs lying around, but does anyone have any ideas what steel this is likely to be?
Many thanks,
Ian
Sounds likeSkoda spring steel to me.
your. best bet if you have a lot is to have it analyzed, otherwise sounds like a reasonable HT . Try oil quench and see if it still looks good
-Page
So, ya made a test knife out of it, it cut through metal without damaging the edge, it is super hard to bend? Sounds like you have some good stuff to me. :thumbup:
