Recently I slapped this device together from stuff I had lying around the garage. It holds a 1" x 42" belt like a bowsaw blade, and tension on the belt can be adjusted with the red-handled lever device (one of those woodworking jig-related things from Rockler Hardware). The lever device also releases tension immediately, allowing for quick belt changes.
In use, you can either put the blade in a vice and run the belt over it, or hold the tool in your lap and pass the blade back and forth like a strop. When the blade is in a vice, it works best if the two vertical "legs" are gripped as handles. This, along with the adjustable tension allows a very precise amount of convex edge bevel to be placed on a blade. In addition, you can see exactly what progress you are making and tailor each pass of the belt accordingly.
All my khuks are paper-slashing sharp at the moment, so I tested the tool out with a 220-grit belt on a Ontario Machete blade. Frankly, I think it may work better than my motorized belt grinder. The 220-belt removes metal fast, but not so fast that you can make a little mistake and screw the whole thing up. Also, the blade doesn't get hot.
So, if you don't have the space or money for an electric grinder, you can make one of these for about $10 - and you won't have to wear a dust mask using it either.
Maybe at some point I will get some 2" x 72" belts and make a 2-man crosscut version. Anyway, many thanks to the wife who allowed me to postpone putting up Christmas lights until I was done tinkering with this.
