Gentlemen,
I just got my first belt grinder to try my hand at knifemaking, the popular Craftsman 2x42. I have some questions.
I've been convexing blades by hand with sandpaper/mousepad, but I wanted to mechanize the process. I removed the platen from the sander and proceeded. However, I am getting flats. I suspect my technique is wrong, and that I may need to modify the machine.
Does "slack belt" simply mean to use the belt without the platen, or does it mean to adjust the tension in the belt? It seems like lessening the tension would cause tracking problems, but I'm not sure.
How hard should I press the blade into the belt? Enough to cause a noticeable bend in the belt? I have been using fairly light pressure.
Lastly, the sheet metal guards that fit over the pulley assembly (and that the platen bolts to) prevent me from getting much force against the belt, as they prevent me from being able to push the knife towards the belt. I was using the sander last night thinking that I could cut some reliefs into the guards. Has anyone done this?
Thanks. I apologize if such questions have been addressed before. I searched (I am a paying member), but I got nothing specific. I would imagine there's some good youtube videos, but I'm temporarily on dial-up.
Thanks,
Dan
Thanks,
Dan
