- May 29, 2004
So I made a slip joint folder using .093 15N20, both blade and spring. I must have assembled and disassembled this thing 100 times fitting it all up. Nice tight snap both opening and closing. I finished it. Done. Peened pins, this one is for me. I buffed up the scales, polished it, open it one more time to admire it and "ping" the spring breaks off. Faaaaaa! Aaaand gone. Needless to say, my disappointment level is extreme.
Anyway, the spring broke probably because it was too thin. I had ground down the actual spring portion to about 1/16". I came up with this dimension after disassembling a couple of old Buck knives that I have. My question is, how thick should I leave that portion of the spring?
Both blade and spring were heated to 1480, quenched in Parks 50, and the spring was tempered for an hour twice at 575. The broken end of the spring has what I would consider to be a tight small grain. Comments ans suggestions would be greatly appreciated, thanks, Steve B
