So Lo,
How do you put that beautiful polished edge bevel on that there Schatt? I am very envious of your talents.
All freehand on the stones in this pic
A BAD pic, but you can see the new edge about midway up the main blade here
I do most of the work on the small, course dia-sharp, then after the bevel is set I move on to the Brown Spyderco "Profile rod," with the last few mins on the brown I tip the spine up off the stone a tad to start setting the micro bevel, then drop it back down for the white "Profile stone," last few mins are again working the micro bevel. This Micro bevel is not much, just a very small amount... but will help ease touch ups to near nothing. Also makes the edge very strong, lots to gain from a micro bevel and zero to lose. IMHO
So after I come off the white Profile stick, I use that big white stone. It's a Spyderco 306 ultra fine (the best stone money can buy and my most used sharpening stone, because it's about the only thing you need for touch ups... And I do that everyday.. It's takes seconds)
Rant over
OK, so remember to work that micro bevel a bit on the ultra fine, by now your whitting hair via holding the hair, so let's go sharper.
Strop, very light... I lay the knife way down, past where I sharpened at, this helps clean up and stray grind marks. Keep doing that for about five mins., then start working the main bevel for a few mins...
Now this next step is VERY important, raise the knife up and strop that micro bevel, VERY VERY light. Do not over do it here, it's very easy to strop too much on this last step and dull your edge. Too much or too much force will roll the strop around your edge and dull it. I use maybe, ten very light strokes on the micro bevel.. Also flip flopping every stoke, up untill now your stropping and sharpening strokes do not have to be even, just look to see where your at and what you need to do. But stropping this mirco bevel NEEDS an even amount of strokes on each side.
Strop on your jeans, just to get the compound off the blade, hold your knife with the edge facing up, lay a hair across the edge, pull on the hair (ie pull the hair down, and with the WEIGHT OF THE HAIR ONLY you should be able to split a hair right up the middle, it will curl like the hair in the pic)
When I get a new computer I am going to make a few videos of what I do, as it works better than any "system" I have ever tried including the EdgePro Apex. And, I might have $130 in stones
Sorry for the looooong post
