Hey guys, was thinking of putting up a little how to on brass washers, wondering if anyone would actually be interested and if you would rather it on her through Flickr images or on Instagram
here’s all the pics in an album. I don’t have photbucket so I can’t put them up with every step but this should work
Also sorry they aren’t in order but after you go through the steps they should make sense. If not just ask
https://www.flickr.com/photos/189139927@N03/albums/72157716630067006/
1: get all your tools ready you’ll need some files to shape the washer, a drill press to drill the Centre hole and a bit of your choice, a square to make sure your press isn’t out of alignment, sandpaper, granite surface plate, a scribe, a hammer to flatten the cutout, tin snips to cut your washer out of the brass. And there’s a few more specialty tools as well.
2. first thing you need is to get the material of your choice, mine was brass, I started with .030” thick too much thinner and you could run into problems while shaping the washer with your file i.e. bent washer
3. Drill a hole through your material making sure you have enough meat on each side for the size washer you need
4. Now, that piece of micarta I have in the photos has a hole drilled in it, a piece of flattened mild steel would work better, drill a hole through your little steel plate to the OD you want your washer. Mine is 1/4”. Then Center it around the hole you drilled in your brass and scribe around it, get it as centre as you can, the accuracy of the washers all depends on how much time you put into them
5. Now just cut your washer out of the brass making sure not to hit the lines
6. With the snips the cutout will be pretty bent and mangled, I just put it on my surface plate and LIGHTLY tap it until it’s flat
7. Now your going to put the square piece you have in the vice and knock all the corners off, then proceed to rounding it and getting down to your lines.
8. Now your ready to lap your washer, you’ll see in the photos I have a big chunk of aluminum I drilled a hole through, in that hole is a piece of brass rod that I slip the washer onto, then you level it with the aluminum block place it on your surface plate with sand paper and start sanding to the thickness you need, you can get them very thin this way. I typically make .005” thick washers. Now I’m sure you could build a better jig to lap then this but this works. I am designing one so if it work I’ll post the designs.
9. Now your done!!! Now you can say you handcraft you own washers and add 2-3 cents to your knife
sorry if any of this didn’t make sense if not feel free to ask questions please. I’ll answer them best as I can.
