Good day gentlemen. I have a couple of fairly new axes that I have Lindseed oiled and used. They are still as slippery as goose snot. I have read that bees wax will give a better grip. Are there any other alternatives ? Thank you.
A factory finnish ? I hadn't noticed that on my G.B. small forest and Wetterlings hatchet. Thanks for the tips.
Gransfors and Wetterlings don't come with the "factory finish" referred to above. The above comments would apply to most stand-alone (replacement) handles and to some mfrs. such as Council, in which case a clear-coat or varnish would be on the wood. Applying linseed oil to such a finish would result in a perpetually slippery handle -- the clear-coat would need to be sanded off first.
Sorry for the confusion.
-ben
I like the finish tung oil gives, though BLO penetrates and protects better, supposedly.
Maybe try an initial BLO treatment, then use tung oil for upkeep.
The best tung finish is let it dry for a day or two, then a quick rubdown with fine steel wool and repeat. A few times doing this and it will give a nice dark (darker than BLO anyway) finish that is slightly grippy and tough. Old timers use tung oil on their rifle stocks.
