- Sep 23, 1999
I thought I posted about this when I first got it up and running but I did a couple searches and couldn't find anything.
This sander has made such a difference in the quality of my folders it's amazing!
It makes keeping everything dead flat and square a no brainer.
That in itself helps makes your folders work smoother.
I initially built the sander for deburring and just cleaning up parts. I had no idea it would help me so much on my folders.
I used a dc geared motor I bought on Ebay and a controller I already had. I made the base disc out of an aluminum disc and an aluminum hub. Since it turns so slow, 50 rpm, the thing doesn't need to be dead center. I drilled a hole through the disc and hub and put a bolt through them. Then drilled 4 holes through the disc into the hub for screws. It's held up fine so far.
The discs that have the sand paper on them are cut from a salvaged computer desk. It's laminate so it's smooth and hard, perfect for gluing sand paper to. I cut 11 discs out and I glue up 60, 120, 220, 400, and 800 grit paper on them. It's nice to be able to change grits quickly on a disc sander. One trick I learned for removing old sand paper from a disc is to spray it with WD40 and let it sit for a while. It usually peels right off. Then spray some WD40 onto the disc and use a sharp wood chisel to clean the rest of the glue residue off and wipe it clean with alcohol or acetone. Sure is a lot easier than scraping the paper off.
The black line on the laminate disc is a witness mark and corresponds to a groove I filed in the aluminum disc. Makes it easier to line up the pins with the holes.
I just wanted to share this with you guys and suggest that any of you who are thinking about getting into folder making should get one these slow turning horizontal disc sanders. You'll love it!
Take care folks!
Michael
Take care folks!
Michael
