Has anyone successfully been able to slow down a Craftsman 2 x 42" grinder (1/3 hp)?
Correct, Medic, but with the speed, you will also lose power, and the craftsman isn't the strongest one to begin with.
If a sander has a disk on the other end of the motor shaft, take off the disk and mount a pulley.coil up the power cord and do not plug it in. Mount a second motor below the sander, and run a belt to it. Either use a VS motor, or mount a pulley of the size to make the sander run at the required speed. When you no longer need the sander, you can re-mount the disk and sell the unit as it used to be.
I have done this and it works well for making a slow speed sander.
Rayban I would like to see more pics of how you rigged yours up to run a different motor. Looks cool!
