holdanedge
BANNED
- Sep 16, 2002
i am now worried about my beloved bm770. if i grab the handle at the end and grab the tip of the blade with my other hand i can wiggle the blade back and forth. if the blade is in the closed position i can wiggle the very tip only all the way from one side of the handle to the other. about 1/4". as far as i can tell the pivot is not loose in the liners. so, can this small blade actually flex with very little pressure applied to it? if it does i am ok with that. i just hope it is not the pivot that is loose, since that is not exactly a quality i look for in a good knife! if i try to move this assembly by grabbing the thumb studs and rocking back and forth there is no play. that is why i do not think it is the pivot. plus i cannot visibly see the pivot move. is the pivot loose and i just cannot notice it, or can this little blade indeed flex? the torx on the pivot is pretty darn tight. so if it is the pivot the knife is shot. i do not want to send this back because it was a very limited edition that came complete with a titanium gift box. plus, i paid quite a bit more than a regular 770 goes for. if they replaced it with plain 770(that will probably have the same problem) that would suck! what do you experts think?
thank you,
holdanedge.
thank you,
holdanedge.
