I found this two unfinished knife in shop and ..............I have no idea what i was doing ....I have this small piece of 3mm .thick HSS steel so I grind this without thinking to much
Now i think i like it .Well second one/ like on drawning / i will like more for sure .Idea was to grind all from one side , other side flat .All grinds are on contact wheel only different angle .Plan was to have dagger but capable to cut some things better then pure dagger . Whole edge where is that yellow line would be cutting edge .Part close to handle will cut like ordinary knife / I mean on geometry / rest of edge because of angle would be same sharpness but more stronger because of narrow hollow grind ....and whole blade would be much stronger because it was grind just from one side .
What do you think ?
What do you think ?
