small flash II problem
the knife is great. i love it and carry it all the time. I have run into one small problem though. hope you guys can help me out. I brushed against a swing set and somehow the chain caught the clip and pulled it out of my pocket.
there was no problem but it bent the clip a little (bout .75 mm) from the handle of the knife. now it doesnt stay in my pocket as tight as it did before
I figure i will take off the clip and bend it back then put it back on the knife. One problem. that is the smallest allen wrench i have ever seen. the smallest one i tried was 1/18. Does anybody know what size i need.
Thanks
Lee
put something under the top of the clip that will raise the bottom of the clip a little ways from the knife (I suggest a small screwdriver blade), then push the end of the clip (the part that is raised) against the knife, remove the object inserted in the top of the clip and the clip should be tight again.
I always get this one confused. I can never remember :confused: if it is a Torx T5 or T6, but one of those will remove the screw that holds the clip in the hande. If you have any other questions Steve in the consumer services department can help you out. Try emailing him at info@sogknives.com.
Enjoy
Chris
