Small Sebenza Bradley Alias II side by side comparison
STR
Knifemaker/Moderator
Moderator
I have had my Sebbie for a little while now and its like the third one I've owned. This one I'll keep because I modified it to suit my big hands. My thoughts have always been that the Small was too small and the Large handle was great but the blade was just more than I ever need on the large. I still wish Chris had an in between or at least offered a third choice in handle lenght for guys like me with bigger hands seeking ample handles but preferring smaller blades. This is one of the reasons I like knives like the Para Military by Spyderco and the CQC14 concept by Emerson. They fit the bill for my hands perfectly and the blades are just right size wise.
I recently had MasterChief contact me asking about me working on his Bradley Alias folder for him and I must admit that this knife model and company somehow flew below my radar until I started focusing in on it after that thread from MC. I know I've heard of the company and the maker but I guess the fact that they went production eluded me somehow.
Anyway, I ordered an all titanium Bradley Alias II for myself finally after dwelling on it a while and and it arrived earlier today from my favorite pharmacy.
First thoughts right out of the box are that this litle folder is very impressive. I like the blade shape, the edge and the thinness of the profile. Yep its all good there. The bad? The detent ball held the blade closed so very tightly that I was forced to immediately take the knife apart to give the ball a couple taps to knock that thing back in the hole a bit more before I found a happy medium for my thumb to live with. Other end line users might have returned it for this complaing that the thumb stud was tearing skin off their thumb or that it was too hard to jump start to open it. I simply fixed it to my liking but I guess I'm not the average or typical user.
Now that this is done its perfect for me. This detent grabbing too much has come up before with some productions and even customs and I've done it myself, quite recently infact where I had to adjust this for a customer so its no big deal. I guess its still better than the ones that don't grab at all though. Can we say "Gravity knife!?"
Anyway, for about half the price of the Sebenza this Bradley Cutlery folder is not a bad alternative at all for those wanting a Sebbie but not wanting to fork over the dough to take the plunge. In available small frame locks I rate this one number two right behind the Sebenza. In some ways though it is a step up.
For one the Bradley folder comes equipped for both tip up or tip down carry for pocket clip mounting options. For another the design of the handle actually lets me feel that I can get a better four finger grasp of it without feeling I want or need to slide my hand up on the folder more to get my index closer to the blade. This happened so often for me with the Sebbie that I finally just modified it to suit me and built in a choil on it making it the equal to the PT from Strider only far more comfortable in my hand to use.
The Sebbie does have ambi thumb studs. The Bradley does not.
The Small Sebbie I have with Micarta inlays weighs in at 2.7 ounces
My new Bradley Alias II weighs in at 2.9 ounces.
My Sebenza has lock cuts to spring the lock x 2 and both measure at the thinnest to be about .054 which I've always said is quite good when you look around at what other makes have for this measurement. I've also noted that the Sebenza has a smaller slightly thinner cut in the middle of the two larger cuts.
The Bradley Alias II I have has a single medium size .055 lock relief cut puttting in in good company in my opinion. (and also in my pocket.) The Bradley also has a smaller slightly deeper cut in the middle of the larger relief cut. Looks to be that both these smaller cuts on both models go down an additional .005" or so.
Both blades are S30V steel. Both have some decorative spacers and color to them and both seem rock solid at lock up but don't stick terribly bad at all or feel the least bit grainy when opening and closing them. Both also sport PB washers in the pivot.
Speaking of the pivot.
The Sebenza has a bushing in the pivot surrounding the barrel for easy action.
The Bradley does not sport a bushing but its silky smooth just the same although I'd have to give the edge to the Sebbie here but its not by much.
The Sebenza has a screw down blade stop.
The Alias II has a pin that inserts in from inside and is held in place by the screw construction and pivot tension.
Both folders are .125 thickness for titanium frames and locks. And as you can see from the pictures both measure and compare quite well for size and footprint in the pocket. Actually my Sebenza measures .120/.121 thickness which accounts for its lighter weight I think.
Bottom line is that both these are very nice little folders and that I wanted to point out the differences and the similarities for those interested.
Is it a Sebenza. No not quite there but you know what. I feel its so close that for half the money you sure get a lot and don't miss what you didn't get with the Bradley. I might also add that the Bradley came with a nice little pouch in a gray color and a nice box. The Sebenza of course sports a bigger box and a lanyard.
I guess it all depends on what you want. If a pivot bushing, ambi thumb studs and a screw down blade stop are worth the difference to you I'd say go Sebenza and if not the Bradley sure fits the bill nicely.
Pic compare: http://www.bladeforums.com/forums/attachment.php?attachmentid=101699&d=1214780101
STR
i would love to see kershaw use thru fasteners like the bradley - i love the idea of not being threaded into the opposite ti side-my alis is as smooth as any knife ive ever had-its pure butter
the thumb stud was sharp,it smoothed out from heavy work edc use-
size wise its a dead ringer for a leek -the ti is thicker with the bradley than a ti leek-its a beefy leek maybe more than a sebenza-
I don't have a Bradley but I do have a Sebenza. From your photos, the Bradley looks sleeker and might fill the hands better. I always prefer the butt to be be slimmer than the front end of a handle as a natural form for a closed fist!
I've been carrying the Bradley all day and I do like it a lot. Its for sure going to be carried and used a bunch.
By the way. I did manage to remove the thumb stud and install a different one with no problem. I like mine a lot better actually because there are no knurls on it to peel skin.
STR
Good comparison STR... I also have wondered how the Bradley would compare to the Sebbie.
With Sebbies you always hear the complain that the S30V is run to soft, reason why many prefer the old BG42.
As both knives have blades from S30V, do you see any difference in edgeholding and sharpening ?
I think people get the "run too soft" thing confused from the A2 one piece line, which they do run intentionally soft. The edge retention on my Sebenza is on par with any S30V knife I've ever used, easily.
I have never had a single issue with the Sebenza S30V. I have had issues with S30V in the past but its most always associated with the thinness of the edge or the blade profile and geometry being to thin for the uses its designed to tackle and not the heat treatment.
As to how it cuts. I've had it not yet 24 hours so I can't say how it cuts yet.
STR
Nice comparison STR. I'm glad this review will be out there for people who are not sure wich one to get, I took a little gamble when I ordered my LE G-10 model. I figured how could I go wrong with a Ti framelock for that price? I recentley read a small review somewhere else that mentioned some differences regarding the finishing touches on the jimping, I do not have a Seb to compare it to but I don't see or feel any problems there. The only thing that bothered me a little was the thunb stud but it looks like we can take care of that :)
I bought both the Alias I and Alias II about a year ago. I bought them because I wanted something similar to a Seb but at about 1/2 the cost. I carried the Alias II around for several months. Very good knife. The problem I had with it was that the blade grind didn't seem to work for me that well. After cutting a couple of tie-wraps, I would have to sharpen it. I had to do this repeatedly after cutting. I don't know what I was doing that was any different than using other knives. I have since bought six different Sebs. I EDC a small regular now and I've used it for cutting tie-wraps, opening boxes, dressing out small game and I haven't had to sharpen it yet. With that said, I gave both of the Alias' away to one of my sons and my brother. They're nice looking knives, feel good in the hand and are very similar to the Seb in materials, but they just didn't work well for me.
How do they compare when cutting things?
I notice the Bradley's grind is a little lower and also looks to be flat?
Unfortunately, if my small Sebenza is representative of others, the edges are a tad thick in my opinion (.023" on mine).
On my two the Bradley seemed a bit better out of the box for slicing ability. I had to thin down the bevel on the Seb initially to get it where I like it personally. Having carried the Alias II for a day and a half my thumb is sore because the lock is equipped with some agressive grooves and it sticks a mite which makes it a bit challenging at times to release it to close the blade. The sticking has gotten worse with break in so the lead pencil trick has been needed several times today on the Alias II.
The detent ball had something to do with my thumb soreness also but finally I got that where I wanted it. Its a great alternative knife to a Sebenza but its not the Sebenza. Due to the choil I put in my own small classic its tough for me not to carry the Sebenza and in fact its back in my pocket while I give my thumb a breather. Between this Bradley and the three Emerson conversions I've built for members into some massive .160 thick frame locks lately my thumb has had its share of breaking in locks this week. Good thing I have two of em :D
STR
I finally worked it in so the Bradely is nice and smooth now. I've relisted it for sale now since I'm comfortable with it working as it does now.
STR
I like the blade of the Bradley better and the size and handle of the HD better. But still both fall a bit short for my own needs. Both are made well though. The Bradley is a fine folder no doubt about it.
STR
Steve, in your opinion, does the screw fastened blade stop substantially strengthen the construction of the knife for torquing, prying, etc.
I know torquing and prying with a folder constitutes abuse, but sometimes we have to abuse our knives in an emergency.
Thanks so much,
Jim
I've always preferred screwed down stop pins more so for the prevention of a rattle. For example, all my Emerson folders rattle because of the stop pin being placed in the holes and only held in place by pivot tension. Some of my Kershaws do too but most of those are older ones. The newer ones seem to exhibit a higher tolerance where the pins fit better so there is minimal or no slapping of the sides back and forth between the liners.
I just replied about the construction of what I percieve to be a 'good liner lock' in my forum for someone that asked me. Its still on the front page if you want to view it. Most all that is regards to liner locks but a lot of the same things can apply to any integral locking folder.
Generally speaking the longer the handle and blade are the more leverage you can garner against the contact and the more flex you can exert on the liners. This is particularly troublesome on thinner lined folders with integral locks. So anything you can do to make the construction more rigid to prevent excess flex is a good thing.
Thanks
STR
