Small Sebenza clip hole size
Hi BF members,
Can anyone help me measure the clip insert size for a small Sebenza 21? I'm trying to find a deep carry clip for a Southard Tolk and the insert size looks similar in picture but I only have large Sebenza's, so I need some help confirming the size...
From my measurement, the Tolk clip insert size is 12.5mm x 7mm, I'm hoping an after-market small Sebenza deep carry clip and insert can fit it.
Thanks in advance!
I believe that the clips are the same on the small as they are on the large. The hole should be the same (not 100% sure though)
Yes, they are the same in diameter, and since the 21 they are now the same length as well.
On the older one's the screw for the small was shorter so you couldn't see it when you looked inside the frame. They were also lower in profile, and had a more polished finish. The clip screw was also as low in profile as the other screws/pins, which it isn't any longer.
There are several little things I miss about the Classics and Regulars, and is why that's all I have now.
