I'm going to be building a small shop in the back yard in the future & am looking for input as to the layout.
The attached picture is pretty self explanatory. I'll be building a shedrow style building 12 ft. deep, with 2 bays or rooms 10' wide & an open "run-in" that is 8' wide, for Storing the woodpile.
I'll potentially expand my shop section to be 12' wide but am planning it out at 10' so that any extra square footage will be a bonus.
The middle bay will be yard tools storage & gardening centre for the wife, although I'll be putting the compressor in there as well!
The air will be piped in to the workshop. Bicycles will likely get stored there during the winter months.
Obviously design is dictated by function. I would like to use the shop for knife making while keeping it versatile enough for household wood working projects.
The main feature will be the Shop Smith multi tool which will replace a number of stand alone tools & be the most space effective solution. They have even been modified to run a grinder which is what I intend to do. This will serve as the table saw, router, drill press, bandsaw, planer, etc...
The other tools shown are:
Circled V = Small Shop Vac, for clean up & dust collection. It'll fit under the Shop Smith
6" Jointer
Circled G = Garbage
G/B = Grinder / Buffing station
Mitre Saw
Trusty workbench!
Everything will be on rollers & if you look at the shops door, it is a double hinged Dutch style barn door. I'll keep everything on the level of the lower door so that I can run the work out the top while using the door for support if needed.
The mitre saw work area is the same height as the workbench & the jointer work area so that shorter pieces can be run onto the bench & longer pieces are run out the door.
The grinder is on a rolling stand so it can be shuffled around as needed.
I'll be making liberal use of the wall space as well for hand tools, charging station, material storage, clamps, finishing equipment, etc.
This will be my first dedicated shop & project of this nature. Is there anything I am missing that a well equipped small shop should have? Design or layout ideas? The plan is done in excel so is quite easy to modify.
Thanks!
S.
6" Jointer
Circled G = Garbage
Mitre Saw
Trusty workbench!
Thanks!
S.
