I have had one of the Chinese benchtop grinders for many years. Cooling is a problem, and steel warpage from just one or two passes can be a royal pain, the steel pulling off the mag chuck from stresses building. Especially mill-rolled barstock. Forge scale clogs the stones quickly.. knock it off with an angle grinder first.
There are cooling systems out there that will help. One utilizes water mist so you don't build up alot of wet. Another uses air, utilizing the principle that forcing a gas through a small orifice causes it to cool.
No experience with either one, but they're available from MSC.
One must turn bar stock over frequently to keep streses even, and without cooling the bites are limited to about 1-2 thou. Aside from that, these are surprisingly good surface grinders for the bucks. I replaced the funky three-rod main handle with an extended wheel-type; it makes it alot easier.
