Small Tibetan Sword
Rusty
Moderator
Moderator
A week ago Saturday, after the afternoon session of the convention we met at the Titanic.
While Yangdu was putting the stuff off the table away, including the large Tibetan Sword displayed on the table, I saw her pick up from somewhere a small Tibetan sword. I believe that someone may have seen it earlier and put dibs on it, thus, it's being taken off the table.
Anyway, they had another, and I got it. In a red leather scabbard, of course.
Thirty one&1/2 inches long overall, 8 inch handle from guard to buttcap. Brass bolster a bit more than an inch and a quarter behind the steel guard, and brass pommel the same length. Five and 1/4" black water buffalo horn slabs riveted to the full tang, shaped octagonally, with a swell in the center. Add 1/4 inch for the keeper at the end of the butt cap, which goes from oval next to the horn to eye shaped looking down on the butt, with hemispherical keeper and a steel "rat-tail" end to the tang, peened over like on the khukuris.
Forward of the guard is an inch-and-a-half long by 1&3/4" deep habaki style brass thickener. The guard itself is 4" top to bottom, and 1&1/2" wide around the handle tapering to roughly 1/2" at the tips. It is made in it's entirety of 3/16ths inch stock.
Blade to forward edge of guard measures 23&1/4". Thickness of spine is 5/16ths 2 " ahead of guard tapering to 3/16ths 2" behind tip. Depth of blade in front of guard is 1&5/8". It tapers to 1" 3&1/2" behind the point. The grind at first appears to be flat ground but turns out on inspection to be slightly hollow ground thus reducing weight a bit more. The spine drops slightly, bringing the point down to the center line. I have no means of measuring the weight unsheathed, but putting it in the sheathe adds 1" to OAL.
So much for the mundane facts.
Most of this past week when I've been seated at my computer, it's been sitting on my lap. And when I haven't been on the computer, I'm often working to true up it's edge or polish the blade...this one isn't there yet - but it was the last one left and not up to Bura's usual work or I wouldn't have been able to afford it. It's marked L. B. and shows Bura's 1/4 moon mark.
One guy has already asked if I'm going to round off the octagonal shape and reduce the handle size much as I did the AKBowie. Truth be told, I don't know. The large side flats do well to orient my hand on it.
There's a transformation going on. I'm not sure if it's to the sword or to me. But we continue to become acquainted. Mama Cass' voice keeps ringing in my ears "... and it's getting better, warm and warmer, strong and stronger, getting better every day, better every day...".
OOOooo... I went to see LOTR TT again yesterday. Can't help but get excited about swords after that :p... Yours sounds like a beauty!!
Its time to go play with my kat!
Alan
Balance 4" ahead of guard.
Feel: like a conductor's baton. That's an exaggeration. There's plenty of weight but it can be moved quickly and without two much strain.
Wrist will need a bit of strenght built u[ to use properly. Not that much though.
Not perfect yet, Raghorn, but it's getting closer.
I think it's perfect precisely because Bura gave us the opportunity to help him finish it. He's never done that for me before. ;)
My major problem is how can I make it my every day carry ( EDC ). I want to take it with me wherever I go, but I can foresee some problems resulting from that. Like an increased interaction with LEO's and mental health.
And when the current mental health guy first headed for grad school, he was accepted but his grants didn't come thru. At the time I just dropped by and assured his mom ( who'd worked for me when I was with Welfare ), a good Catholic mother, that God would have a plan for her boy, one way or another, and left the current catalog for the Jesuit School of Theology, Berkely with her for him.
Edge is now pretty much straight, with one barely noticeable dip in it and another quite slight bulge. The heck of it was the temper was too high to cut with a file. Had to sand or stone it down to even. Then I had an edge with a big flat on top. File, on edges, stone, sandpaper.
So from now, am going back and getting 800 and 1000 grit paper to polish the sides. Then to 1500 to finish til can pick up 2000 or even 3000. But it's now usable as is. In time will even up the bevels, sharpen to razor's edge, etc.
It'll do for now, and better in the future. Now maybe I'll try making a single bladed dagger. a 15" blade ought to do fine, and I've got a 17" blade in reserve.
Rusty,
HIKV Sword style! The Tibetan is a great short sword. Think Bura hit it just right for dimensions. I see you noticed as I did that the edges on the swords need a bit of work. Keep at it as the end result is worth it. The hardness makes sharpening a bit of work but with the right tools and time it can be done. This sword is definitely not a light weight even though it feels light. The thickness across the spine makes it sturdier than the Katana. Kinda like that myself.
