Small wheel grinder
Some time last year, I just got tired of messing with those sanding drums on my drill press. I was asked to post a picture of this very inexpensive small wheel setup that I did in my shop so here it is. I used an old 1725 rpm bench grinder, about a three inch length of radiator heater hose, a large washer and the idler from a Kalamazoo grinder for tension.
As far as the idler goes, just about any setup imagineable can be used, it was just convenient since I already had the Kalamazoo mounted to the table. (The Kalamazoo is still operational but it is in "semi-retirement" since I got a "more better" grinder)
I placed the large washer over the shaft next to the bench grinder housing so the belt wouldn't cut into it. I then placed the heater hose over the shaft as a "contact wheel". I then lined up the bench grinder with respect to the idler on the Kalamazoo grinder idler wheel. On these grinders the tension arm is set with an allen screw, it can pivot all the way down to the table if so desired. Tracking is adjusted on the Kalamazoo end.
The really neat thing I like about this set up is that I could have bought the small wheel attachment for my Hard-Core but accessory change out on a grinder is an inconvenience, regardless if its Hard-Core, Bador, Burr-King, Wilton, etc. It is just so much easier to have it set up already, ready for use.
This setup works fast and it works well. I can now use any grit belt AND belt change out is a breeze. This is so simple to do I don't know why I didn't do it sooner.
C Wilkins
[This message has been edited by C L Wilkins (edited 05-13-2000).]
I like it! I have a grinder motor just like yours that will soon be converted into a Wilkins notcher. Thank you very much!
It is better to bear the rebuke of a wise man than to enjoy the flattery of fools.
CL
I have a grizzly griner,the idler
wheel moves up and dow I can go from 72 to an 80 inch belt. I my set one up under
my my question do you think I have a grinder that is 3/4 horse it turnss 3450 do you think it will work,it will be turning
a big idler whell tha will slow it down a great deal.I have a cotte also and the small wheel attachment is a pin to set up takes 20 minutes to do.Nice idea. give me some feed back
That's really slick.
I was in Gary Gouker's shop up in Sitka, Alaska, and he did the exact same thing. He had a little Baldor 1/3 HP buffing type motor and he got ahold of some felt block. He drilled the felt out enough to screw it onto the shaft, and then just turn the motor on and shaped it. He made one contact 1" and one 1/2"
Thanks for putting up the pics, it's a fantastic idea.
Nick
