Here is the solution:If my one favorite slipjoints has a small, almost unnoticeable wobble on the main blade, can it still be used reasonably?
Wonderful, I actually will do that. Great answer. It is a 34OT.so nothing to hit with a hammer, I think.Here is the solution:
Take a stick about 1 inch in diameter and strip the bark off it. Sharpen one end of the stick, then cut a notch in the other end. If you didn’t feel the blade wobble doing all that, it’s fine. Try not to keep wiggling the blade to check if it wobbles.
If its a USA Schrade from the mid (?) sixties on, it has Swinden key construction and you are correct - nothing to hit. As you describe it, I'd keep using it and start looking for a back-upWonderful, I actually will do that. Great answer. It is a 34OT.so nothing to hit with a hammer, I think.
I have two stainless versions bought in Scranton 04. When I realized that my first pocket knife was an Old Timer 80OT.which I gave to a friend, was in carbon steel I was bummed out. Alas, two years ago someone sent me a nos from the seventies, free of charge, as a present.. He had read about my missing having an Old Timer in 1095. What a guy. So I carried one stainless version from 2004 to 2019 so the sawcut delrin became smooth and now I carry the old timer carbon. I have a drawer full of possible substitutes, however the 34OT is one of few I really carry. They are all American I believeIf its a USA Schrade from the mid (?) sixties on, it has Swinden key construction and you are correct - nothing to hit. As you describe it, I'd keep using it and start looking for a back-up
I don't know if the Chinese Schrades are Swinden keyed or not.
That’s a very good point and I agree 100%That said, I understand why knife nuts worry about it. I bet my great grandpa would never have checked or cared.
I have a 80yo Schrade stockman that’s been beat to hell and back. Sharpened on a grinder and brutalized. It’s as tight as a submarine. In my experience, with a slipjoint, if you use the knife, the wobble will get worse. Custom makers consider wobble a flaw and will fix it for free. I don’t buy new knives with wobble
I don't believe this will accomplish anything with Swinden key construction.I have had good luck by doing this:
Wrap the pivot with multiple layers of newspaper.
Place the pivot end carefully in a bench vise.
Very, very lightly tighten the vise a tiny bit. Check the blade for results.
If needed, try again.
Do not overdo it! A tiny bit is all you need, as you take the risk of over tightening.
You are correct, my mistake.I don't believe this will accomplish anything with Swinden key construction.
