Smith and Wesson SWHRT3BF blade customization
Hi everyone. I picked up the smith and Wesson swhrt3bf a couple days ago. It is a reasonably sized fixed blade boot knife/dagger. There is a larger version of this knife which has a double sided blade. However, that model was too big for EDC so I went with the smaller version. The one problem with the swhrt3bf is that one side of the knife is false blade. I used a dremel tool in an attempt to remove the false edge and actually had fairly good luck in doing so. However, I can't seem to get the edge as "fine" as I would like and am weary of using the dremel to grind much further. If anyone has any tips as to how to make the blade more "fine", such as a specific angle to clamp the knife at when I grind the edge with the dremel would be greatly appreciated!
